Ok, I read a post somehwere addressing why there's no sound in Ulead DVD MovieFactory or Workshop but can't find it with a search. How can I resolve this issue?
Thanks!
Ok, whille I'm waiting on a repsonse from one of you pros, let me tell you my process and maybe this will help provide a solution. Since I'm new, I'm sure I'm doing something wrong or missing a step. I want the easiest yet most effective dvd burning solution.
1) I record my vhs tape to the hard drive on my e80
2) high speed dub to my dvd-ram disk.3
3) Put the disk in my LG GSA-4040b PC drive (which does recognize ram disks) and copy the vro, pub and ifo files to my computer.
4) Rename the .vro file to .mpeg
5) "Import a video" in DVD MovieFactory 2.
6) Create the menu and chapters.
7) "Ouput" to dvd-r.
I never hear sound in MF2 from the movie itself. When I add background sound to the menu, that sound DOES play properly as well as on the output. But, the movie audio is never their, not even when burned to dvd-r and played in a standalone player.
Please help! -
Buster,Originally Posted by busterw
The reason you don't hear sound is due to the fact Ulead DVD MovieFactory 2 does not support AC-3 audio compression, which is the type of compression utilized by the Panasonic player/recorders.
To author AC-3 sound, you'll need to upgrade to Ulead's DVD WORKSHOP AC-3 described at the following link:
http://www.ulead.com/dws/runme.htm
(Also be advised Ulead has just announced version 2.0 of DVD Workshop.)
As an alternative, I seem to recall there's a way to adjust the Panasonic player/recorders to utilize LPCM audio instead of AC-3 audio compression.
If you switch your player/recorder to utilize LPCM audio and then import any files recorded with that setting, you should be able to hear audio using Ulead DVD MovieFactory 2.
Ulead DVD MovieFactory 2 supports both LPCM and MPEG AUDIO.
Hope this helps,
Jerry Jones
http://www.jonesgroup.net
DVD MovieFactory 6 Chapters
By BillyBollocks in forum Authoring (DVD)Replies: 0Last Post: 2nd Nov 2009, 14:26 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 15:54 -
DVD MovieFactory 6
By Mike99 in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2008, 06:14 -
DVD MovieFactory 6 Plus
By ozab in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 17:48 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43
