hi,can anyone tell me if my pc has enough power to drive a dvd writer
...it's a celeron 900mhz...128mb sdram...20gb hard disk drive...any info
appreciated...![]()
you`ll be able to write but not do anything else at the same time especially if you are on winxp,best to get more ram,256mb at least.
yes more ram, followed closely by a bigger hard disk. Defrag often. Close non-essential programs ( screensaver / antivirus ) when burning.
I have a buddy that is running a simular setup. I gather from him that it takes considerable more time to burn, but it works.
Yes, you can burn DVDs with a 300Mhz PC. The real limitation with your system is your HD. DVD5 discs are 4.7Gb and DVD9 discs get up to 8.5GB. So unless that's 20MB of freespace you're going to run out of room.
Also any processing is going to take 2x the source size, at least. Eg. backing up a DVD9 discs to a single DVDR. You have to rip the DVD to the HD, then encode. That's a 14GB job minimum, if you re-encode w/ CCE or TMPGenc then re-author the sizes goes up by a factor of 3x.
IDE HDs are cheap. When you get your burner just buy the biggest HD you can afford (these days 60GB drives are all but free). Extra ram and CPU speed are needed to PROCESS your projects, but not to actually burn them. That is you want them, but they aren't necessary.
So it's HD > Ram > cpu (cpu is actually fine I got by with a K62 500Mhz for a long time everything was just slow as hell).
PAL or NTSC camera : does it matter ?
By kirby7777 in forum Authoring (Blu-ray)Replies: 9Last Post: 14th Aug 2011, 15:51 -
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 11:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 23:59 -
Why does the disc speed matter with the burning?
By coody in forum DVD RippingReplies: 20Last Post: 31st Jan 2008, 19:39 -
Does it matter what you use to capture DV tapes to computer?
By deacea in forum Capturing and VCRReplies: 2Last Post: 19th Nov 2007, 00:20
