  1. I can create standard menu but don't know how to create motion menu?
    Thanks.
  2. Start project; select menu (on the top); hit cancel to avoid Ulead's standard menu templates. On the left side of screen you have two selection buttons. With the left, select background video-general. With the right you load (import) a video file to be used as menu. Once imported you drag and drop it to menu list (lower part of screen). Now some more settings are available such as duration of motion menu etc.
  3. Some good step-by-step tutorials for Ulead DVD Workshop - including motion menu tutorials - are available on the Web page at the following link:
    http://www.ulead.com/learning/dws.htm
    Hope this helps,
    Jerry Jones
    http://www.jonesgroup.net
    Jun 2001
    Israel
    Is there other guide for this issue (motion menu) except on ULEAD site?
  5. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    MM,
    This may be of interest to you:
    https://www.videohelp.com/forum/userguides/131158.php
    I just got DVD Workshop, so I havren't had a chance to try it yet.
    Good Luck !!
    Moonstomp.
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
    Jun 2001
    Israel
    Thanks Moonnstomp
    I will try it.
  7. There's also a book and a step-by-step training guide:
    http://www.ulead.com/edu/Material_authoring.htm
    Jerry Jones
