When I try to "import asset" in adobe Encore it gives me a message that says it does not support this type of file or it may be corrupt. I have tried an avi clip and a mpeg project. both say the same. The only thing that I havn't tried is a avi project that I have edited in Adobe premier, but I don't know why that would make a diffence.
On a side note I can import a menu from photoshop.
Any ideas or suggestion would be appreciated
Of all the problems I have had with Encore I haven't had any problems importing assets. I would assume the stream you're importing is corrupted somewhere. Use TMPGEnc or Premiere to reauthor it to something and see if that cleans it up enough for Encore to take it. I'm pretty sure it won't allow importing of certain codecs as well like divx files. What MPEG compression is the other file in?
end of file--Adobe Encore
By koberulz in forum Authoring (DVD)Replies: 19Last Post: 18th Oct 2016, 21:21 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 14:21 -
Adobe Encore CS4: How to reduce output file size?
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 8th May 2010, 13:19 -
Trouble Importing MPEG videos
By xroflmaowtfx in forum EditingReplies: 2Last Post: 10th Mar 2009, 00:30 -
Problem importing Russian subtitles into Adobe Encore
By adanepst1 in forum SubtitleReplies: 2Last Post: 29th Jan 2009, 14:12
