  1. Hello, I'm still new at this but I have some Avi's with 4 audio tracks (eng, commentary, etc). I believe the audio is ac3 and I'd like to basically make the avi's svcds with hopefully more than one audio track. Using virtual dub, I can only extract the english track. When converting an avi with tmpeg, only the english track is there. I'd like to know what program can help me extract at least the commentary so I can add it to the svcd. Thanks.
    Jan 2004
    Germany
    Hi there,
    I had the same problem, but I found help in this forum. You should use VirtualDubMod.First load your avi file. Then you can select Streams in the main menu and then choose Stream List. A new window opens and you get every audio stream in your avi file listed. You can choose each stream and export it to wav.
    I hope this helps you out.
    Daywalker
