When i use re-author with dvd shrink 3.0 and move the main movie, according to the guides mentioned here, to the new window, deselect the subtitle's and audio languages then the indication bar on the ride side of the screen indicates 4420 (all green).
Then i use backup and when it is finished the total size of alle the files that dvd shrink 3.0 creates is 6.7 gb. That is the total size without compression for the movie!
Dvd shrink doesn't shrink?
Does anywhone has a solution for this?
I am using winxp pro on a amd 1000 ghz with 512 mb memory.
