I have encoded a file to videocd Pal with TPMGenc and as it was 83 min long I used tmpgenc to chop off the last 3 mins so it would fit on one cd now then i tried to burn the cd using nero it said that the file was not suitable and i would have to reencode the file so I used mpg corector and now nero says the file is over 90min long and it will not fit on one cd what should I do now????
