Is this possible in DVD-Lab? I have some cool AVI video loops and would like to use them as an animated background behind motion menus (scene selection menus). Is this workable in DVD-Lab?
vcddude
Yes, this is possible with DVD-Lab. The company website has tutorials with this exact example. Check here: http://www.mediachance.com/dvdlab/tutorial/index.html
As far as TMPGENc DVD Author, I do not know. -
check the feature list on the DVD Lab website - they have added more tools in the newer versions for making motion menus directly in the program.
if you have a program that will allow you to do video compositing (Adobe AfterEffects, Sony Vegas, or Zwei Stein [freeware] ) you can take your motion chapter clips and put them on top of your motion background, and render it all as one big mpeg, then use that as your motion menu, adding links and text with the authoring app.
I personally prefer this method, as a) it allows for more flexability and customization than the limited tools available in the authoring app, and b) looking at the instructions to do this directly in DVD Lab, it seems like you have to jump through a lot of hoops for the output you get.
as far as I know, TMPG DVD Author supports motion menus, but I don't know how good or robust it's creation tools are.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Yes, not only is it possible, but it looks COOOOOOL! Makes it look like a store bought DVD!Originally Posted by vcddude
housepig
yes i have done motion menus with T-DVD Author...it's the animated background (
) that the motion thumbnails sit on that i'm interested in
DVD-Lab Pro 2: How to set a looped video as background of a menu?
By Stern77 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2010, 12:00 -
Scene Selection Menu in DVD-lab Pro2
By jole in forum Authoring (DVD)Replies: 5Last Post: 25th Feb 2009, 04:20 -
Chapter screens for scene selection menu question?
By ecc in forum Authoring (DVD)Replies: 3Last Post: 17th Feb 2009, 15:49 -
Create DVDLab DVD Scene Selection Menu
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 09:22 -
DVD Lab, Is it possible to add video to background on the menu
By frozenwind in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2007, 11:09
