    Oct 2002
    new york
    When i try to convert a avi to dvd the movie comes out elongated what ca I do to stop this
  2. Member Devanshu's Avatar
    May 2003
    What do you mean by "elongated"? Do you mean that the file was small as an avi and filesize of the encoded file increased? If so, then that's to be expected...that's suppose to happen.
    Oct 2002
    new york
    No I mean every thing on the movie looks like it has been streached heaught wise. Everything looks skinny and long
  4. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    Turn your set on its side. That way they will look short and fat.
    Did you check on the FULL SCREEN-KEEP ASPECT RATIO?
    Oct 2002
    new york
    I'm sorry I forgot to say that I used Tmpgenc to convert
