My first post on any forum.
I have an AIW 8500DV, bought in Jan. I have had all the typical problems I.E. installed to see a black screen until I disabled firewire, still lose the left audio chanel daily because IRQ 11 is shared between the capture card, SB live, and modem. I have spent many hours trying to separate them to no avail. I don't care about that anymore.
Question. It doesn't matter what I capture I lose a considerable amount of the original video's sharpness and the colors, for the lack of a proper term, appear very muddied.
If my source is TIVO or PVR the loss, although disturbing, is acceptable. But I have yet to capture a single minute of home video that is not completely disapointing. I have spent aprox 12 hours trying to adjust the color, contrast, and brightness while capturing. I give up only to try again in a few weeks. I have come to the conclusion that I will have a MUCH better copy of my home movies if I just dub to another VHS.
Is this normal? The best to be expected?
Results 1 to 12 of 12
It is full size vhs. It is not, of course, the greatest quality. The TIVO and PVR on the other hand are.
I am happy with the original tapes, I just want copies for my parents, but want to know if my $200 capture card is supposed to be this crappy!
Thanks for answering. -
I'm sorry, but I don't have experience with VHS, and I don't have an ATI card.
Here are a few things:
- Use an S-VHS deck. The color is stored seperate on the tape. It has to be combined to go out thru an yellow rca jack. An s-vhs deck uses an s-video connector. This keeps the color seperate.
- When you capture I assume it is directly to mpeg. The ATI may be softening the picture.
- Invest in a test DVD like the AVIA or Joe Kane one. This will let you not only adjust your tv but also you monitor/capture card by playing the dvd thru the card with a dvd player. You can use this to adjust your colors/sharpness/contrast of the preview of the card. -
Thats for the info about the test DVD. I have wished for a simple color bar like the ones the stations broudcast when they go off the air. I guess with cable and sat. that doesn't get transmitted any more.
You may have found the word to describe what I am getting out of the capture. "Soft" Is that a flaw in the card or MPEG.
As I said. I have tried for many hours 12+ to adjust the color, brightness, and contrast but nothing helps.
Does anyone out there with a 8500DV have the same problem with "soft" color and sharpness? -
Hello Eric,
I have experienced similar problems with lose of sharpness and colour bleed with my captures also. I am in pal land - Australia.
I have been using a digital analogue converter (Datavideo DAC-100 and TBC-1000). I haven't had much time lately to try all the many settings but I have tried quite a bit of software to date. My setup
Panasonic VCR > TBC-1000 > DAC-100 > Audigy firewire > sonic foundry Videofactory2.0
I have converted to CVD, SVCD and DVD but still the same issue. The footage is not bad, just "soft". Any filters I have used tend to smooth too much also.
I initially thought the problem might lie with VideoFactory capture utility. I tried the help forum on VideoFactory but got no help at all.
I tried capturing with SceneAnalyser Live but get interlace artefacts and noise. My next step is to swap the VCR and try capturing a few different tapes. I have also tried VirtualDub and frameserving straight into TMPGEnc but no improvement.
I am interested in any answers you get also.
Cheers and good luck! -
Thanks. Glad to know that it isn't a bad card. The next capture I try is going to be between 2 VCR's. haha. I'm tired of wasting time on this futile attempt.
Without knowing your capture settings, it's hard to give advice.
Quality is not bad at all capturing from TIVO or PVR but it doesn't matter what settings I use from VHS. It all sucks. Not resolution mind you, just color brightness and sharpness. I suppose it is due to the input signal but I would have expected fair in fair out, but I am putting fair in and getting total crap out. Is this to be expected??
Thanks -
I repeat myself.Originally Posted by lordsmurfWant my help? Ask here! (not via PM!)
MPEG 2
720x480, NTSC (525)
8.00 M bit/sec
48.000 Khz, 16 bit, stereo
MPEG 1
352x240
2.4 M bit/sec
AVI
640x480
UYVY
Changing the settings doesn't help! Not even changing the color, brightness, and contrast. -
If you are using the ATI presets, they are crap. Go to Lordsmurf's site and read up.
http://digitalfaq.com/
Losing color quality after conversion
By vain in forum Newbie / General discussionsReplies: 12Last Post: 10th Feb 2012, 18:05 -
Chroma/Color Bleed Issues In MPEG2-->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 8Last Post: 25th Jun 2011, 22:11 -
Can I remove color and letterbox MPEG2 video without losing quality?
By gamgamman in forum EditingReplies: 3Last Post: 10th Jul 2008, 23:22 -
[SOLVED] color quality changes between players
By jdetwile in forum LinuxReplies: 6Last Post: 14th Mar 2008, 10:23 -
Color correction issues.
By ziggy1971 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jan 2008, 23:17
