http://www.softpedia.com/public/cat/11/2/3/11-2-3-1.shtml
VirtualDub is a video capture and processing program. It features fast capturing, process files larger than the 2 gigabyte limit, optimized for linear editing, support for Motion-JPEG, MPEG-1 video and layer 3 audio, real-time and near-realtime video processing, video job queues, and much more.
What's New in This Release:
[features added]
* DirectDraw support is disabled when Terminal Services
or Remote Desktop clients are detected to work around
a DirectX clipping bug.
* Re-enabled places bar on open and save dialogs.
* Disabled FPU state warning and made the fixup silent.
WAY too many drivers are screwing up the FPU unit.
* Edit lists can now be omitted from configuration
files without needing to close the source file.
[bugs fixed]
* Main window is disabled during MPEG-1 scan to prevent
crash if main window is closed.
* Previous-key and next-key movement commands were not
correct for B-frames in an MPEG-1 file.
* Fixed decoding of MPEG-1 B-frames at the start of
GOPs with broken_link set.
* Palette change blocks no longer appear as garbage
video streams. In-stream palette changes are still
not supported, however.
* biSizeImage was incorrect when using fast recompress
in YV12 mode.
* Sequence appends failing on the first file now throw
an error rather than a warning.
[regressions fixed]
* A race condition in the fast write code occasionally
resulted in spurious write errors.
* Fixed swapped 00db/00dc tags in AVI output.
* Fixed display of 8-bit paletted video.
* Program starts under Windows 95 again.
Results 1 to 1 of 1
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
re: virtualDub
By merlie in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 14:50 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
