Hi all. I have been quite happily converting from XVID to DVD for some time and then authoring using TMPGEnc DVD Author and burning to DVD. It's all been going well until recently!
I have two movies (two files each) and join them using VirtualDub. I then use my template as normal in TMPGEnc and encode to DVD. However TMPGEnc crashes randomly and bombs out.
I have tried converting separately (i.e. each file on it's own) but still have the same problem. I have checked for bad frames and tried to remove them but the VirtualDub I have does not create a list of the bad frames - it only tells me it has some.
I have tried VirtualDub MP3 Freeze and this crashes randomly as well.
The video files play back fine so it is quite annoying!
Any ideas?
Results 1 to 11 of 11
Have you tried any of the video fixers in the tools section?
https://www.videohelp.com/tools#VideoRepair/Fix
I'm not sure if DivFix can repair xVid's - maybe, as they're similar codecs AFAIK.
cheers,
mcdruid.
P.S. they'll playback fine because players tend to be much more tolerant of errors than encoders can be. -
I had a problem with with this as well. do a search for Enviormental settings mentioned above and change these settings. worked for me
Hi there. Could you do me a favour and post your environmental settings so that I know they are working ones please?
P.S. Apparently there is nothing wrong with the avi file itself!
Cheers all! -
Hi there. I have tried changing the environmental settings but it still crashes. Do you have any other ideas on what it could be? or what I could try to stop it doing this? I don't understand why these two films are causing me trouble when I have had no problems with any other XVIDS before! Apparently I have all the right codecs installed according to AVIcodec!
What else can I try?
Thnaks all! -
Get good source material.
/Mats -
Hi all I read a post about using FourCC to change the movie to a DIVX rather than XVID. I did this and it seems to have worked. It's 93% thro encoding so fingers crossed it should be ok! I only download DVD rips and usually have no problems with anything so it is a strange one! Thanks for all your help!
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 20:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 21:00 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 16:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 17:33 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 01:31
