Problem with Maddogmultimedia Prowler MX-440-SE installation: The PCI graphics card supporting PCI 2.0(or higher) is not getting fixed in my PCI 2.2 motherboard because of two notches of the graphics card not matching with the slot of the motherboard. Why is there this incompatibility issue ? Is there any adapter available with which I can use this graphics card in my PCI 2.2 slot ? Is any any other solution ?
vsenapati
STop ! the nothches are there to prevent cards being put into either the wrong slot or a slot with the wrong voltage. Your card probably requires 3.0 volts supply and some adapters only supply 1.5v . Inserting the wrong card in the wrong slot will fry the card. check its correct slot PCI/AGP? and if AGP check for correct voltage.1.5/3.0 ...
The electronic components of the power part adopted a lot of Rubycons.
Different installation problem
By dmf in forum ffmpegX general discussionReplies: 9Last Post: 11th Jan 2012, 16:02 -
I have some problem with wvc1dmo installation.
By Dboyz in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2009, 04:23 -
FLVtool2 installation problem
By linea in forum ffmpegX general discussionReplies: 34Last Post: 15th Dec 2008, 13:09 -
Problem with the installation!
By defacta in forum ffmpegX general discussionReplies: 3Last Post: 20th Jul 2007, 00:37 -
By gokes in forum ffmpegX general discussionReplies: 1Last Post: 10th Jun 2007, 04:55
