does anybody know where to get this program?
i have heard that it can capture directly from DVD to MPG2.
is this true?
has someone tried it yet?
http://www.intervideo.com/
It can capture directly to MPG2 but not ture DVD frames size.
The capture size are 352x240, 480x240, 640x240, 720x240.
how's the quality? I'm thinking of getting one too. Is it easy to use. can you burn it straight with Nero?
so that means you still have to encode it? does it take long? do u use the same program or something else?
how to increase the image capture size in winDVR. i want to capture a frame of 640*480 any clues???
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 14:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 17:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 16:34 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 19:01 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 11:39
