Hi all,
I have DVD Workshop 1.3 with AC3 pack, both patched.
I use video (.MPV) and audio (.AC3) separated files.
It seems this software does not allow importing the AC3 file, which has 5.1 format.
If I merge them into a MPG file, DVD WS accepts it, but it re-encodes the whole file in the final step.
If I transform the AC3 file into MP2 and the I do the previous operation, all works well without re-encoding, but I lose the AC3 function.
Any suggestion is very appreciated. Thanks in advance,
mauro
Results 1 to 16 of 16
If you have the AC-3 version of Ulead DVD Workshop, you should be able to import AC-3 5.1 surround sound files and then re-encode them to become 2-CHANNEL stereo AC-3 files.
I've done that successfully here on my three workstations.
(I have Ulead DVD Workshop with the AC-3 PowerPack applied.)
If you are unable to import the 5.1 sound, then there may be a technical issue associated with how the program was installed.
You might try uninstalling and re-installing.
If you keep having problems, I'd suggest giving Ulead's tech support team a call:
1 (310) 896-6391, Monday-Friday, 8:30am-5:00pm (PST).
Hope this helps,
Jerry Jones
http://www.jonesgroup.net -
I used to use 1.3 without the AC3 pack to author 5.1 AC3 dvds. What I did was to mux the m2v and ac3 file in tmgenc into an mpg, then open that in workshop, author and burn with the "do not reencode compliant ect" box checked. Worked fine. Don't see why your muxed files are being rencoded, as long as they are compliant.
To answer SPECIALIST who says:
<If you have the AC-3 version of Ulead DVD Workshop, you should be able to import AC-3 5.1 surround sound files and then re-encode them to become 2-CHANNEL stereo AC-3 files. >
I don't want to lose the 5.1 features I already have in my AC3 file, nor I want to spend useless time to re-encode the audio.
To answer NOLONEMO
if I mux audio and video into an MPG file (I used AVI2MPG2 or BBMPG), Ulead re-encode the whole file even if I set the check box to DO NOT REENCODE COMPLIANT".
Thanks to you both for your support
mauro -
Yes - I realize that.Originally Posted by mauromi
However, the product is advertised as follows:
"Import 5.1 Surround Sound and create Stereo AC-3 files"
http://www.ulead.com/dws/runme.htm
The program does not officially support authoring of 5.1 surround sound.
Unofficially, however, you should still be able to 'pass through' the surround sound data by checking the DO NOT CONVERT COMPLIANT FILE check box that appears on the final MAKE DISC burn menu page.
But I would also recommend that you carefully inspect the properties of your source MPEG and then *adjust* your DVD WORKSHOP PROJECT SETTINGS to match in every way.
For example, if I import files with the following properties:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 704 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Variable (Max. 8800 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 48 KHz, Stereo
...I am careful to match my Ulead DVD Workshop project settings to match.
You can adjust the DVD Workshop project settings by clicking MAKE DISC and then by clicking CUSTOMIZE.
Hope this helps,
Jerry Jones
1. In windows change your folders options to "show hidden files and folders "
2. Go to C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead DVD Workshop\1.0
3. Open with notepad DVDWS.ini
4. once opened search for this line..
PlayAC3=0
Change it to PlayAC3=1 ( it may already be 1)
Now below that one, you make a new one ( see below)
ADVANCE=1
Closed the file, and save the changings..
Now you can load without any problems an Mpeg with ac3 sound in it.
When you choose for “Make Disk/Customize” that there is a new Advanced option,
where you can change the settings and bitrate etc for a AC3 file.. -
In response to Taxiback
Thanks, it seems the right solution!
But I don't have this file
. Trust me, hidden files are shown, the problem is probably that I'm using version 1.3 wiht AC3 which stores such information in the registry.
However, even the registry does not have the PlayAC3 option.
Under <hkeycurrentuser>-Softare-Ulead Systems-Ulead DVD Workshop-1.0 I have several sub-folders:
- BURNPARAM
- Default
- Library
- Premerence
- PROGINFO
- Recent File
- VIO
but the PlayAC3 entry does not exists.
However, can anyone tell me how to set the right options in disk template manager to avoid AC3 conversion is forced? I tried to use any of the predefined ones on a MPEG file with AC3 5.1 384 kbps inside, and the audio is always converted.
Thanks again!
mauro -
Quick update.
I re-installed dvdws and now I have the DVDWS.INI file.
I changed the tow entries to:
PlayAC3=1
ADVANCE=1
Now it seems that the audio is not converted (although the log seems to say the opposite, see below) but DVDWS spends 10 seconds on the first 3 steps and then 40 minutes to do the multiplexing step.
I'm owndering what is it multiplexing if I already have both audio and video in the same file.
This is the log result of building a new image, thanks in advance for any help
mauro
Service Pack 1 (Build 2600)
[2003/11/10][11:17:23.49] DVD Log file
[2003/11/10][11:17:23.49] Project properties block
0001: Project name: TheMatrix
0002: Project folder: D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix
0003: Total menu pages: 0
0004: Total titles: 1
0005: PAL (25.0 fps)
0006: Do not convert compliant file, non-compliant file will be converted to follow project template
0007: Accept Mpeg audio for NTSC DVD
0008: No anti-flickering filter applied
0009: Do not create DVD folder
0010: Create disc image file
End of properties stuff block
[2003/11/10][11:17:23.49] ESTIMATED Project size: Based on the project properties.
0001: Total project size: 3454462848 bytes
0002: Total project block: 1710126 blocks
0003: Total extra size (for converting title and audio, and motion menu): 1506470400 bytes
0004: Total extra BLOCK (for converting title and audio, and motion menu): 745778 blocks
0005: Exact disc image size (based on the generted disc image file): 3454462848 bytes
0006: Extra disk size for converting video: 0 bytes
0007: Extra disk size for converting audio: 1506470400 bytes
0008: The size of non-converted video: 1947275648 bytes
0009: The size of non-converted audio: 0 bytes
0010: The size of motion menu: 0 bytes
0011: The size of still menu: 0 bytes
0012: The size of still images: 0 bytes
End of size stuff block
0001: *[DVD:FAIL] Can not Reuse VOB folder
0002: =======================================
[2003/11/10][11:17:23.49] Convert Titles
0001: =======================================
0002: Try to extract audio from a video clip, video source=X:\f\TheMatrix.mpg
0003: =======================================
[2003/11/10][11:17:23.64] Converting audio file (to be LPCM format)
0002: CodecID = 0
0003: Audio CodecID = 1
0004: current data rate = 0
0005: Display ratio = 0
0006: Save Frame Rate = 15000
0007: Save Frames = 0
0008: Save Samples = 376617600
0009: Save SamplesPerSecond = 48000
0010: Save file name = D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix\~TheMatrix_000.wav
0011: Save Width = 320
0012: Save Height = 240
0013: Save video track = 0
0014: Save audio track = 1
0015: Save BitCount = 0
0016: Save BitPerSample = 16
0017: Save Channel = 2
0018: Save Data Track = 2
0019: =======================================
[2003/11/10][11:17:23.64] Dump MPEG_PUBLIC_OPTIONEX
0002: Audio Type = 0
0003: Mpeg flag = 0
0004: VBR Average bit rate = 0
0005: File format = 0
0006: File type = 0
0007: Sample rate = 0
0008: Audio bit rate = 0
0009: Bit rate mode = 0
0010: Frame height = 0
0011: Frame width = 0
0012: Frame Rate = 0
0013: Layer = 0
0014: Mode = 0
0015: Output Frame Mode = 0
0016: Version = 0
0017: Video data rate = 0
0018: =======================================
[2003/11/10][11:17:23.64] End of Dump MPEG_PUBLIC_OPTIONEX
0001: Do extraction: out file=D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix\~TheMatrix_000.wav
0003: Check and convert background audio file of image slide show title
0004: =======================================
0005: =======================================
0006: Check and convert background audio file of menu page
0007: =======================================
0008: [DVD:OK] Generate new cache VOB folder [TEMP] D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix\~f\
[2003/11/10][11:32:51.18] After DVD-video folder (D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix\~f\VIDEO_TS) is generated, show all size stuff.
0001: Total project size: 1936936960 bytes
0003: Total extra size (for converting title and audio, and motion menu): 0 bytes
0005: Exact disc image size (based on the generted disc image file): 1936936960 bytes
0001: [DVD:OK] Re-generate disc image [FORMAL] D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix\THEMATRIXac3.iso
[2003/11/10][11:56:21.24] After DVD disc image (D:\Documents and Settings\mauromi\Documenti\Ulead DVD Workshop\TheMatrix\THEMATRIXac3.iso) is generated, show all size stuff.
0001: Total project size: 1937506304 bytes
0005: Exact disc image size (based on the generted disc image file): 1937506304 bytes
[2003/11/10][11:56:21.24] Begin dump of Remaining time log data
[2003/11/10][11:56:21.24] Data Rate of item=5907_1_data, MID=5907, SID=1, data rate = 482224.351691
[2003/11/10][11:56:21.24] Tick Rate of item=5907_1_tick, MID=5907, SID=1, tick rate = 0.013959
[2003/11/10][11:56:21.24] Data Rate of item=25654_1_data, MID=25654, SID=1, data rate = 9523809.523810
[2003/11/10][11:56:21.24] Tick Rate of item=25654_1_tick, MID=25654, SID=1, tick rate = 4761.904762
[2003/11/10][11:56:21.24] Data Rate of item=25791_1_data, MID=25791, SID=1, data rate = 2092320000.000000
[2003/11/10][11:56:21.24] Tick Rate of item=25791_1_tick, MID=25791, SID=1, tick rate = 277.777778
[2003/11/10][11:56:21.24] Data Rate of item=25792_1_data, MID=25792, SID=1, data rate = 100000.000000
[2003/11/10][11:56:21.24] Tick Rate of item=25792_1_tick, MID=25792, SID=1, tick rate = 50.000000
[2003/11/10][11:56:21.24] Data Rate of item=25655_1_data, MID=25655, SID=1, data rate = 869565.217391
[2003/11/10][11:56:21.24] Tick Rate of item=25655_1_tick, MID=25655, SID=1, tick rate = 434.782609
[2003/11/10][11:56:21.24] Data Rate of item=25793_1_data, MID=25793, SID=1, data rate = 50000000.000000
[2003/11/10][11:56:21.24] Tick Rate of item=25793_1_tick, MID=25793, SID=1, tick rate = 5000.000000
[2003/11/10][11:56:21.24] Data Rate of item=25794_1_data, MID=25794, SID=1, data rate = 1000000.000000
[2003/11/10][11:56:21.24] Tick Rate of item=25794_1_tick, MID=25794, SID=1, tick rate = 20.000000
[2003/11/10][11:56:21.24] Data Rate of item=2029_1_data, MID=2029, SID=1, data rate = 16666666.666667
[2003/11/10][11:56:21.24] Tick Rate of item=2029_1_tick, MID=2029, SID=1, tick rate = 3333.333333
[2003/11/10][11:56:21.24] Data Rate of item=5901_1_data, MID=5901, SID=1, data rate = 2841778.027897
[2003/11/10][11:56:21.24] Tick Rate of item=5901_1_tick, MID=5901, SID=1, tick rate = 0.121811
[2003/11/10][11:56:21.24] Data Rate of item=5902_1_data, MID=5902, SID=1, data rate = 22064579.275905
[2003/11/10][11:56:21.24] Tick Rate of item=5902_1_tick, MID=5902, SID=1, tick rate = 0.945787
[2003/11/10][11:56:21.24] End dump of Remaining time log data
Sorry, it's me again to give my last update.
After several tests I discovered the following bug: if the file is "small" (up to some hundreds MB) the process works well without re-encoding.
But is the file is big (I tried with 3 GB)DVDWS re-encodes the whole file, taking several hours.
Furthremore, the multiplexing steps always occurs.
To summarize, I will use a different software to prepare my DVDs.
mauro -
mauromi,
I'm no expert on DVD Workshop and I haven't used it lately but I have created DVD's larger than 3 gigs with it and the files weren't re encoded.
Well I should say that my first attempts did result in the file being reencoded but that was due inexperience with the program and changing a setting in the template that seem to make the assets appear non-compliant to Workshop even though I had the box checked not to convert compliant files (my wording for that option might not be exact). I also hadn't applied all the patches to the program from Ulead. Have you done that step?
You indicate that, correct me if I am wrong, but isnt' multiplexing a part of the process of merging all your projects assets into the VOB files that get recorded to the DVD?Furthremore, the multiplexing steps always occurs.
I got some help with DVD Workshop from another forum and you might want to take a look at that thread.
http://www.dmnforums.com/cgi-bin/disppost.cgi?forum=ulead_dvd_workshop&filename=030905095829.htm
Hey use whatever app you feel comfortable with and gives you the results you want but Workshop is pretty good and if set up correctly will do the job. -
Well, you could try unistalling everything, and install 1.3 only without the AC3 pack and see if that eliminates the multiplex step.
The multiplexing step is normal.
The step that one should try to avoid is RE-ENCODING.
I do that successfully using Ulead DVD Workshop routinely.
However, I work with stereo AC-3 files and not 5.1 surround sound files.
There's a new version 2.0 of Ulead DVD Workshop just around the corner...
...with more robust features.
Jerry Jones
Version 2 seems interesting, but I'm scared of the sentence
>>Dolby® Digital AC-3 Support – Import 5.1 channel
>>Dolby Digital audio files and encode to 2-channel
>>Dolby Digital stereo. The best quality audio at the
>>most compact file size means more space on the disc.
I hope it means that it does BOTH things, but not not mean that it does not allow to create a DVD with AC3 5.1, even if I have the source audio in this format. -
Surround sound output does not appear to be supported.
However, the program will have a feature called SURROUND SOUND EMULATION.
The PDF file that explains this feature states:
"If the original audio track uses more than 2 channels (e.g. Dolby® Digital
5.1) but was converted to a 2-channel audio track (e.g. Dolby® Digital Stereo), this option will simulate surround sound when playing back your video on a set-top DVD player."
http://www.ulead.com/dws/dws2/DVD_Workshop_FB.pdf
Jerry Jones
Mauromi, I'm stumped. I authored many 5.1 full discs using Workshop 1.2. I rendered in Vegas to .m2v video stream. Used Softencode to render out an 5.1 ac3 audio file, muxed the two in TMPGENc, imported the resulting mpeg to Workshop and burned with the "do not convert compliant files" box checked. The mpgs were all around 4.3 GB Always worked like a charm.
Re Workshop 2.0: Hmm, it will convert Dolby 5.1 to Dolby Pro Logic? What a bargain! Not. -
Keep in mind, that's just the *official* feature list.
As you've indicated, one can check the DO NOT CONVERT COMPLIANT FILES check box - using the current version of Ulead DVD Workshop - and the 5.1 surround sound import will be passed through to the disc.
I suspect the same will be true of version 2.0 of Ulead DVD Workshop.
Jerry Jones
Originally Posted by Nolonemo
Can't Import Video File with AC3 Audio into Vegas 9 Platinum
By Charlie_L in forum Newbie / General discussionsReplies: 11Last Post: 2nd Sep 2011, 07:44 -
AutoGK hangs during AC3 import process...
By takearushfan in forum Video ConversionReplies: 8Last Post: 11th May 2011, 05:31 -
SOLVED: Can't Import AC3 audio in Virtual Dub 1.9 Stable
By mlong30 in forum EditingReplies: 2Last Post: 15th Jan 2011, 02:12 -
Can't import AC3 to DVD Architect?
By zovx in forum Authoring (DVD)Replies: 9Last Post: 11th Feb 2010, 18:53 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22
