I am interested in the frame size of NTSC captures. It seems to me using iuVCR's built in BT8x driver, one should cap at 712x480 or 754x480 for DVD. This should then be cropped/padded or resized to 712x480 and then cropped/padded to DVD-video size.
Reading Houspig's guide on LordSmurf.com, it is recommended that one cap at 720x480. However, the example shots on iuVCR site show caps at 768x576. 768 corresponds to the 754 number above. 768 is the max width at the BT8x chips sample rate for PAL. To get back to the original picture aspect, a PAL user would size down to 702 and pad.
Any thoughts?
Am I Just crazy? :P
Nobody care?
By the way: As far as caps at 720 vs 352. I'd hazzard to say 90% of the capture cards out there capture the full picture and then resize to the width you ask. SO the only "quality" difference is if you like the cards resize or not. If you want to get the full info back from the card without a resize you need to ask for 754 or 768. If you want the source picture at it's original width, you need to ask for 712 or 702.
Results 1 to 13 of 13
Don't mix PAL and NTSC standards.
Anythingx576 is PAL. Anythingx480 is NTSC. (by anything I mean the usual resolutions, not some oddball like 690 pixels)
You should be looking at 720x480 or 704x480 for NTSC captures. How much overscan you want to deal with is up to you. I usually capture in 720x480 and go from there.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for the comments.
However, I mentioned PAL and NTSC in my post. I was not mixing. I was covering both.
Speaking only NTSC:
Your capture card captures the active NTSC picture as 754 pixels width. That is because it samples at a higher rate than the 13.5 in the standard. For the standard, the active picture would be 712. The card then shrinks the 754 to the width you asked for. If you ask for anything other than 712, the width is too small or too big. The picture is distorted (not very much). 720 is too wide. 704 is too narrow.
Speaking only PAL:
The capture width is 768. The picture width in a correct 4x3 aspect is 702 TV pixels.
Here is a link to the BT8x cards specs: http://www.conexant.com/products/entry.jsp?id=404
Here is a link to a BBC writeup on picture sizes: http://www.bbc.co.uk/commissioning/branding/picturesize.shtml
Here is a good definition of Aspect Ratio: http://www.quantel.com/domisphere/infopool.nsf/HTML/565C7D89F2D64F3680256C8000444A4D
Ever wonder why 720x576 is not 4:3? Well, 768/576 is. Exactly 1.33333333333.And would look good on a square pixel PC. 702 would look good on a fat pixel PAL TV. That is the number on the iuVCR website example page.
NTSC is a bit more complex. OR maybe I am crazy :P
Edit: Sorry, the BT8x spec is a doc on that page. 100199a.pdf. Here is a direct link: http://www.conexant.com/servlets/DownloadServlet/100119a.pdf?FileId=542 -
Originally Posted by trevlac- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Given the source of my captures, 712 or 720 doesn't matter. I usually put TV episodes in 1/2 D1 resolution anyway, so 704 is better since I'm going to decimate by 2 for speed. Usually I mask the outside to black then re-size. My TV is 27" and it doesn't show. In fact, I see the artifacts from the cable TV a lot more than I ever see encoding artifacts.
NTSC is a pain in the butt compared to PAL.
And Yes, IUVCR has a definate PAL flavor to it (the BTWIN drivers force me into PAL only mode).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
housepig:
I don't mean to argue with you. I was just trying to better understand a strange "fact". Tell me to suck eggs if you don't care.
Translating from 768 PAL gives 754 NTSC. This is also for PC AVI watching, not DVD TV watching. If you want to translate from PC to TV watching, you would get 702 for PAL and 712 for NTSC. See the BBC link above for some PAL info.
Actually you can cap at 768x480 because the drivers support that big of a width. I see the initialized buffer on the right when I do this. The card does not provide any info for the driver to put there. It's the famous green color.
Now the differences are not much. I will gladly keep my thoughts to myself if no one cares. For practical purposes, one might use any number that makes making a DVD easy.
Edit: To clarify/correct, 754 is wrong above for NTSC PC watching. 648 would be the correct number for this (648/486 = 1.33333). 754 is the max width the card can give for NTSC. 922 is the PAL number. The drivers may not support 922 as a PAL number. And if you want to be really anal, 711 is the NTSC TV pixel number not 712. 711/486 = 1.33333333711 and 486 are not good numbers for digital. You get 486 because 6 are chopped off of the TOP of the picture. At least that is what I have read. I did not confirm.
Originally Posted by Gazorgan
Why 368 ? Well for some reason, doing anything less is mucked up by the card's resize. Maybe it's the driver (BTwincap) that I use.
Does 352 give you poor results, but 368 look ok for you?
I have a sample of the bad resize. It actually keeps the detail. It just seems to mess up the fields. I'll post a link if I can find it.
Trev -
Have you guys completely forgotten that the player
resizes the horizontal to the DAR so discussions of
Sample Aspect Ratio don't mean much ? -
Originally Posted by FOO
Have you tested what you are saying? In a test I'd bet various DVD players do the frame on pictue thing I described above in slightly different ways. They may throw off the center line. They may pad on top or bottom.
Don't get me wrong. I am just a hobbiest who likes to understand the details. For practical purposed, maybe noone cares.
PS:
A more interesting thing about picture aspect ratio may be that for 30 years movies were shot in 1.37 720x480 is real close to this. To put this on a dvd one would just pad a 720x479 image by just 1 line and then send it to DAC. So (for old movies) is 1.33 really 1.37 seen thru a 1.33 frame?
The math for the above is:
720 * 72/79 = 656 x 479 = 1.36994.
711 * 72/79 = 648 x 486 = 1.33333.
72/79 is a conversion from PC square pixels to NTSC skinny pixels. BTW: PAL pixels are short and fat. (is that why all of those actors on the BBC are short and fat? )
See the bbc link or this one for reference: http://www.quantel.com/domisphere/infopool.nsf/HTML/565C7D89F2D64F3680256C8000444A4D -
I'm simply saying that the aspect ratio of the capture has nothing to
do with the display aspect ratio.
neither of 352 x 480 and 720 x 480 is 4:3, yet they both display
as 4:3 on a TV.
If this discussion is about overscan , that's a slightly different matter.
I don't worry about it. maybe I should.
Does a captured line have more pixels than will display on a TV
when put on a DVD ? possibly
In that case the capture is getting more than is visible, and should be
adjusted. -
Hey FOO,
Let me 1st say I am relatively new to this stuff. However, I have been recently reading the official ITU specs, running some tests, and piecing this together. The specs are free to download and shorter than you would think. I've also been pondering specs from the BT8x implementation of this stuff. These can also be had for free in a pdf.
Originally Posted by FOO1/1 is a square pixel. NTSC TV pixels are 72/79 or about .911. PAL TV pixels have a SAR of 128/117 or about 1.094. See my links above for a confirmation.
Getting this out of the way, we can then calculate the picture aspect ratio of an NTSC picture in square pixels. 711 TV pixels wide by 486 lines is:
711 * .911 by 486 == 648 x 486 == 4/3 == 1.33...
So to bring it on home ... If you have a card that captures the active scan line and then scales it to what you ask (like the BT8x does), then not adjusting it back to the original apect ratio distorts the original picture/image.
Said another way: 711x486 is 4:3. Capturing a 711 image at 720 streatches it.
I don't think 720, 704, and 352 are the aspect ratio of an picture/image. That is dependant upon the source. The frist 2 numbers are just the picture size (in non square pixels) that the dvd player shows thru the 711x486 frame of a TV. Padding and cropping to get to them does not effect the aspect ratio of the picture. 352 is probably streatched to 704 and then just shown with black fill by the dvd player.
adjusted.
Regards,
Trev -
I don't know what you are trying to say.
What I'm trying to say is the capture rates horizontally and vertically
are not uniform, or "square" but that is not related to what comes
out of the DVD player .
No matter what the horizontal pixel count is, the player
will spit out a full scan line that fits the TV width. -
Thank you for bearing with me. I am not being clear.
The following represents the process of DV filming a round ball, broadcasting the image, capping it, and putting it on a DVD at D1. In order for the ball to continue to be round, the steps in the process must be correct. I'm saying not capping at or resizing to 712 with iuLabs (or BTwincap or maybe any BT8x) drivers, breaks the process. The ball will not be round.
In order to follow it is easiest to visualize the initial picture/image passing thru a series of frames as it travels thru the process. I give the frame measurements in square and {non-square ITU-601 NTSC} pixels. The point is that if you stretch the picture after it passes thru a frame, you will be distorting the picture. Your opportunity to do this is between when you capture and put the image on a DVD. If you assume the frame size is not what I give, you are distorting the picture. The frame aspect does not really matter. The frame just crops/pads the picture as it passes thru. I give the frame aspect just as a reference.
Code:Image passes thru Frame Size Aspect of Frame 1)ViewFinder 648x486 {711x486} 1.333 2)DV Spec 656x480 {720x480} 1.367 3)TV Broadcast 648x486 {711x486} 1.333 4)Capture Card 649x480 {712x480} 1.352 5)DVD Spec 656x480 {720x480} 1.367 6)DVD out to TV 648x486 {711x486} 1.333
- This is artificial. I picked this as a clear starting point. There really is no pixel measurement until you go to digital. An LCD on a cam probably is 4:3.
- DV spec captures more picture width than would show thru a TV (with no overscan), and probably more than you see thru the viewfinder. I imagine TV cameras line up with broadcast specs, ITU-470.
- The 601 spec says the with of a 720 image is 53.333 microseconds. Analog TV broadcast spec ITU-470 says the active picture is 52.666 microseconds. To go from one to the other you effectively crop the picture. Analog images are taller than digital images. You have to add 6 lines. (Top or bottom or both, I don't know)
- BT8x cards pull the active picture as 52.740 microseconds. This is probably because 712 is a much nicer number than 711, and the analog spec gives a +/- value. After all, it is analog. The chip also samples at a higher rate than the spec (14.296 vs 13.5). That is why you can ask for up to 754. The card also chops off 6 lines. (Top or Bottom, I don't know). If it's the same black lines as the DV to Broadcast conversion added, there would be no picture lost. It seems it is. VHS tapes may vary. If you cap at 720 you are effectively asking the card to cap a 712 line and then stretch it to 720. Some drivers may be smarter than you an limit what you do to keep the aspect. I don't think the iuLab or BTwincap drivers do this. To test your drivers you could cap at both 720 and 704, pull a similar frame out in virtualDub, and see if the "active picture"s are the same. If they are, the driver is adding a bigger boarder to a 720 cap and cropping the 704 cap. If they are not, the 720 is stretched, and the 704 is squished. The existence of a boarder is not enough to know. The source may have a boarder.
- Going to DVD spec, one needs to pad or crop to 720 or 704, if your drivers did not do it for you. You would also set the DAR to 4:3. Your only other real option here is 16:9. If you did that, the DVD player would try to stretch the picture.
- Your DVD player (thru some analog out, not DVI) has to convert from ITU-601 spec to ITU-470. It sees the DAR as 4:3 and knows the picture is not anamorphic. It then centers the picture on the 53.333 scan line and starts overlaying the edges with analog sync stuff. This will effectively crop the picture to a 52.666 width (711 pixels). It also has to make up for the missing 6 lines. I don't know if it adds them at the top or the bottom.
Since I typed all of this up, could you respond with some type of comment?
Trev - This is artificial. I picked this as a clear starting point. There really is no pixel measurement until you go to digital. An LCD on a cam probably is 4:3.
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Upconverting SD to HD frame size...
By bkelly36 in forum MacReplies: 3Last Post: 24th Oct 2010, 17:31 -
DVD Recorder Captures at Wrong Size
By MasterOfPuppets in forum Capturing and VCRReplies: 3Last Post: 22nd Feb 2010, 20:51 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 00:21 -
Video frame size
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 19:35
