Results 1 to 11 of 11
  1. Hi there,
    I am trying to rip the Vertical Limit DVD and I use he Smart Ripper for it.
    However, when in movie mode the programme always gives the following error :
    "Can't read block 424383 (byteposition 848.766 KB
    Unlock again NOW and retry
    ABORT RETRY IGNORE"
    What is going on ? How can I solve it ?
    I have chosen "unlock drive from the Smart Ripper settings.
    Please help cause I gotta give the DVD back to the person who gave it to me !!!
    Thank you very much.
    <font size=-1>[ This Message was edited by: iparout on 2001-10-10 04:17:07 ]</font>
  2. Try open the DVD with a DVD player (PowerDVD) first ,
    donīt play the movie however.
    So start SmartRiper and rip the movie !
    Not 100% guaranteed ,but always works for me.
  3. I open the movie with Power DVD and pause it and then run Smart Ripper but the error is still there.
    The error always occurs in a specific part of each vob.
    It's my first DVD rip and I'm very dissapointed.
    Also, when I run DVD Decrypter, when it reaches to the point that Smart ripper gave me the error, Decrypter says (can't read from the specified device" and crashes.
    Please help guys.
    P.S. : I have updated the DVD-ROM firmware to make it region-free.
  4. Is it possible that it's a hardware problem or a copy protection of the DVD ?
    DVD Decrypter gives me "Uncorrectable errors" and when I enable the ignore error options, then the movie is ripped but with 3462 read erorrs.
    For example, in vob_3 the ripping starts smoothly, then gives errors for a long time - during which DVD read spead falls to 4 KB/s !!!- and then continues to rip normally till ther end of the vob.
    Same goes for vob_4.
    I'll try to encode to SVCD with those "corrupted" vobs and I'll let you know, however the AC3-to-WAV decoding (just finished) gave a WAV file of 76 minutes' duration, out of a 120 min movie.
    Let me know if you think it's a hardware problem please !!!
    Thx in advance.
  5. Is the disc scratched? Sometimes that stops it from being read properly.
  6. Well, it wasn't obvious to the eye that it was scratched. I mean there was no deep scratch noticable, however I wasn't left with anything else to believe apart from the fact that the disk was defective.
    It was borrowed from a video-club, so perhaps being scratched wouldn't be that difficult, since dozens of people have borrowed it.
    I'll rent another tomorrow and I'll see how it goes.
    I'll keep you posted.
    Take care.
  7. <font size=-1>[ This Message was edited by: pinoy2201 on 2001-10-10 21:29:31 ]</font>
  8. I've succesfully ripped Vertical Limit with SmartRipper several months ago, so I know SmartRipper can do it - The
    error you get will show up no matter what ripping program you use - I've had it on other movies I've rented. When you watch it - you just see a small glitch, but it is kind of annoying that the rippers "die" when they have this kind of problem.
    Jun 2001
    Silver Spring, MD USA
    Whenever I run into difficulties with DVDs and Smartripper, I just tell it to search for the key at every new VOB file ... I think the key sequence (or whatever) changes in the newer DVDs (different key for every vob, or something like that).
  10. Well, it must have been a scratch or something.
    I just finished ripping The Bone Collector without a problem -I hope the conversion will go as well as ripping -
    Well, another QUESTION :
    How can I see the *EXACT* playtime of the movie (without the extra futures, for example behind the scenes e.t.c.) so as to calculate the bitrate when encoding ?
    Thx in advance.
  11. YOu don't say how you normally process the rip once you're done. I use DVD2AVI. You can then use VFAPI to give you a "phony" avi file for the *.d2v file - and from the avi file you can easily get the length of the movie.
    I'm sure there are other ways as well, but this is easy if you use DVD2AVI.
