I got this problem, which I find quite weird.
I tried hooking up my VCR to the Canopus thru SCART -> Adapter -> S-video IN.
As many of you in this forum, I got a b/w picture.
Today I connected the same VCR with the same scart adapter to the S-video input of my Sony TV and SURPRISE!!! I have a colour picture!!
The VCR is not a s-vhs but why do I get colours on TV and b/w on the Capture card?
How can you explain that?
Andrea
I have same problem and have dip switch set to PAL. Also the same with Dazzle DVC capture.
Life is what happens just when you've got everything planned. -
Scratchie.... no, the switch is set to PAL as I'm trying to capture a PAL video.
I wonder if these capture cards are so sensitive that if you don't feed them with a perfect signal, they won't work.
As I said, I plug the cable into the TV and it's colour... plug it into the card and it's b/w!!
Shouldn't I get a b/w video on the TV if the problem was the VCR output? -
It may be that the Sony TV is clever enough to realise that you aren't giving it an S-Video signal so is switching to composite and giving you colour.
Hi,
I refer you to this post it might help a little https://www.videohelp.com/forum/viewtopic.php?t=175019&highlight=
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
Problem with capping on my comp with WinDV and advc-100
By MikeMGMVE in forum Capturing and VCRReplies: 3Last Post: 2nd Oct 2008, 14:19 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
