Hi guys,
I'm totally stuck right now as to which of these players to buy. I have read both good and bad reviews of the Yamada and can't really find a lot of reviews for the philips, I need to order one in the next week but haven't got an idea of which is the best
My main priority is GOOD divx/xvid playback!
What do you guys recommend?
cheers 'n beers
~livEwirE~![]()
I wont answer this but, go to DVD players then input what your requirements are
HINT dvd737 doesnt come up when divx playback is selected!Corned beef is now made to a higher standard than at any time in history.
eh, sorry to burst your bubble m8, but I have double-checked this and the Philips DVD 737 does appear when divx is selected
Does anyone know where I can find user reviews on the dvd 737, NOT in French please
Yea, the dvd 737 is listed with divx, but there are at least 10 reviews there and NONE are in french.
yes you are right... too much looking and not enuff understanding.. still I would recommend the dvx6100 as i have one and it works great.. havent had any problems with it all...tech support are pretty good...answered email within a day.. so you choose. for review in freench try this link and paste the english in there?
http://translation2.paralink.com/Corned beef is now made to a higher standard than at any time in history.
I've read the reviews and am still not 100% sure, will prolly go for the Philips
cheers,
~livEwirE~
getting the Toshiba SD-6100 code free
By geeg in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2010, 08:03 -
Make LG DVX-286 (/ DVX-276) region-free
By joniakaidiot in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Mar 2010, 08:33 -
Philips 737 hack for region 1
By ttchandler in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jul 2009, 10:34 -
Help with a sound issue on a Toshiba SD-6100
By hhcup in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Apr 2008, 10:06 -
NVIDIA GeForce 6100 Vs Radeon 9550
By the_importer in forum Media Center PC / MediaCentersReplies: 5Last Post: 12th Nov 2007, 17:59
