My DV capture device generates bad frames frequently (about 1/min).
These frames have colourful blocks (16x16 pixels) inside with some regular patterns.When I frameserv such a clip to VDub with AviSynth, I can see solid green (0x008600) areas, which consist of 2 or more 16x16 blocks.These areas are only green, when I go directly to the bad frame (^G and frame#).
When I play or preview the clip around the bad frame, the green color is completly gone and replaced by random blocks of the last frame before or after in the clip.It looks like, as if these areas are sort of "transparent" or unrendered by the DV codec.
Does someone know, what's happening here?
I'm asking, because I wanted to write a VDub filter for locating such bad frames by analysing solid areas of the specific colour.It made me curious to know the reason of this strange behaviour.
(I'm using now an AviSynth script, which can surely find such bad frames, but it's quite slow- works only in realtime).
Results 1 to 1 of 1
possible bad frame prob with file from Panasonic miniDVD camera
By ronhud in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Apr 2012, 16:40 -
Mp4 format problem, the vid have a bad quality after i rendered it.
By aisple_aislesz in forum Newbie / General discussionsReplies: 12Last Post: 25th Apr 2011, 10:02 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 19:07 -
TMPGEnc - bad frame problem
By psyklax in forum Video ConversionReplies: 5Last Post: 30th Jun 2007, 22:44 -
bad audio frame
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 14:37
