I have an Pionner A04 had it just over a year now. I have 2 pcs, up until recently in my computer the main computer the dvd drive will not read any disks. Just keeps spining them. But has been working fine for almost a year. So i put it in the 2nd pc, works absolutely fine, Burn disks on it and everything????
thanks for any help.
http://dvd.coldpie.com - where you can download versions of DVD2DVDR.
Faulty IDE cable in that rogue machine ?
PSU on the way out ?
Duff IDE controller ? -
i dont think it is any of them because i have a dvd rom attacthed to the system as well using the same IDE cable. Which elimantes all 3 question?
DVDR = Master
DVD-Rom= Slavehttp://dvd.coldpie.com - where you can download versions of DVD2DVDR. -
Swap the drives around on the IDE cable (don't forget to change the jumper settings too) and see if anything different happens.
Also try the recorder on a different IDE chain. I think you're going to have to try swapping things out one by one between the machines to find out what is wrong, I doubt it's the recorder at all from what you say. -
for some reason i just took it back out of the 2nd pc, and put it back in the same place in my pc ie MASTER. It is working fine again now, How weird, but thanks garry for the tips
No problem, but I'd ditch that IDE cable ASAP, I suspect it's on the way out if re-seating the connector made it work again... !
Problems reading .mts files (possibly corrupted)
By moxiecat in forum Video ConversionReplies: 24Last Post: 7th Mar 2011, 14:35 -
H&B DX-3255 reading problems.
By brianstivala in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Mar 2008, 07:43 -
JVC DR MV-7 reading problems after hacking
By PTCAL in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Feb 2008, 04:47 -
Problems reading MPEG files off of HDD
By tedv in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Oct 2007, 11:20 -
DVR pioneeer 510H disc reading problems
By cistec in forum DVD & Blu-ray RecordersReplies: 5Last Post: 26th Aug 2007, 01:13
