  1. alistair bruce
    Guest
    Have used svcd2dvd for 4 months with no problems but last week it stopped producing vob files . It goes through the process but the output file is empty sometimes an audio and video folder are produced other times the folder is completely empty. I don't know if it has been caused by windows update or what has stopped this program from working. I have gone as far as reinstalling windows, have updated to the new version of svcd2dvd but still can't fix it. Tried mpegs i did last month and they don't work now so it can't be that. Can anyone help (sure bet it was Microsoft screwing something up with a patch they released)
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    To be fair its probably my fault. Been having a bit of a release nightmare over the last day or two. If you re-download the msi file & reinstall. Start & let it update you should be fine again.
  3. alistair bruce
    Guest
    I re-downloaded and reinstalled like you said and it's working again. Thanks for the help one other question.
    When I tried to put 5 mpegs onto one dvd with menus etc nothing was produced in the output file yet the mpegs worked seperately. Does nothing get produced if the output file gets too large for it to fit on a dvd ?
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Shouldn't be a problem. Can you post your log file?
