  1. I have a problem with tmpgenc in 2000 and xp. the program works fine loads and all but when I convert an avi to mpeg the preview does not show video and the program only converts the audio I get a black screen for the video. I have a friend who has win98 works fine. Dows TMPGEnc support win2000 or winxp and if so what Am I missing. Thanks
  2. sounds like you are missing a codec for that avi file...and also Ive been told TMPG doesnt handle avis well in general..
  3. I have been using all the versions of TMPEng under with windows 2000 and windows xp, (duel boot system) and have had no problems, try reinstalling the lastest codec`s
    Paul
  4. THANKS FOR THE INFORMATION, BUT ONE QUESTION. WHERE DO I GET THE UPGRADED CODECS? LOOKED ALL OVER THE MICROSOFT PAGE AND COULD FIND NOTHING. AGAIN THANKS FOR ALL YOUR HELP!
  5. Try this site on the left. Has several links to sites. Worked for me.
  6. thanks for the help..... I had used a intel indeo codec to encode the original *.avi and I guess the tmpgenc wont read or play that codec. switched to the windows video 1 codec and it worked fine. every one got me on the right track thanks. does any one know how to make tmpgenc work with files encoded with indeo???
