Can anyone help. I want to compile a "Best of" DVD from my others DVD and I would like to rip by chapters.
I have try Smartripper but it give me a lots of VOB's and I can not write it with Nero.
Help. Thanks
The simplest way is with DVD Shrink. After opening the DVD, open a reauthor window, drag in the title, select the title, select start/end to select the chapter.
You can easily use this process to bring chapters from many DVDs together. You can even select parts of chapters rather than the whole chapter.
This is great for making selective burn DVDs from many concert DVDs so that you can have just the songs you want. -
I have try ReJib but everytime I add the VOB files it just drop dead and windows shut it down. I'm using a newly install Windows 2000 Pro with SP2.
I will now try DVD Shrink, Many Thanks. -
ReJig and DVD Shrink are the way to go. I think DVD Shrink is a little more user friendly, but either is good. Basically rip everything to the HD, choose re-author and use the start/stop to backup the points you want.
Smartripper does the job just fine, wot do you mean. 'I cant write it with nero' ?
When you rip by chapter DVD Decrypter and Smartripper generate file names that won't be accepted by any "processing program. They need to be renamed to standard format,VTS_01_1.VOB,etc. You can only have nine vob's in set so you probably will need to "join clips" with VOBEDIT.
Finally you need to generate ifo files with IFOEDIT.
[SOLVED] Tool to rip DVD chapters into indivual files?
By sdsumike619 in forum Blu-ray RippingReplies: 3Last Post: 28th Apr 2011, 13:25 -
How To Rip DVD To Separate Chapters?
By Nitro89 in forum DVD RippingReplies: 7Last Post: 14th Apr 2011, 11:06 -
How to rip DVD that has no audio to MP4 w/chapters
By Hijoprodigo77 in forum DVD RippingReplies: 0Last Post: 24th Aug 2009, 20:12 -
rip multiple chapters at once
By xxxjojoxxx in forum Video ConversionReplies: 0Last Post: 18th Jul 2009, 20:42 -
Need to rip chapters from DVDand reburn DVD
By Petraman in forum EditingReplies: 3Last Post: 2nd Mar 2008, 03:49
