I need your help. See my question. I search a high quality Burner
for +RW at 4x?
What do you mean ? Sony, LiteOn or other one ?
Thx
Dickmann
The media has a lot to do with it as well, I'm afraid.
You might find one recorder supports a wider range of media than another, or hacked firmware is easier to obtain that removes the speed limitation safe-guard, but it doesn't just stop with the recorder.
Burning at a speed (or with a write strategy) not suited to the media will give unreliable burns and some players are fussy about what they play when it comes to recordable media. Just because you can burn at 4x doesn't mean you will then be able to play that particular disc back, so prepare to be a little disappointed if you're more worried about speed than compatibility when it comes to playing the damn things back.
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Feb 2010, 00:57 -
What burner would you recommend?
By taboo in forum MediaReplies: 33Last Post: 5th Jul 2008, 13:01 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 02:01 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
upgrading to a DL burner
By efiste2 in forum DVD & Blu-ray WritersReplies: 43Last Post: 27th Jul 2007, 02:51
