I've been looking at this program for a while but with its capabilities is very difficult to learn immediately. Can anyone recommend a book maybe or a detailed online tutorial on using it? This would be a tremendous help. Thanks!
Results 1 to 10 of 10
for links:
https://www.videohelp.com/forum/viewtopic.php?t=185642
Vegas 4.0 manual is available at sonicfoundry.com
there's also a guide from the website of a magazine that I found handy when learning. Will try to find again. -
I haven't crawled through all the links that BJ_M dropped in that other thread, but you should definitely check out the Creative Cow Vegas forum, and the Tutorials linked from there.
Also the Sundance Media Group knowledge base / forum has some good resources - lots of .veg files as examples, plus a bunch of tutorials.
and definitely check the manual - the index is not the best, but if you page through it, it's pretty well written and has some decent examples.
if you have specific questions, post 'em, I'll try to answer or I'm sure BJ_M can help...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Feeling stupid here....
(in Vegas) how can I see a more detailed timeline, like how with Studio you click and drag to extend it (the timeline) to see it in your determined increments?
If you understand, then thankS -
Arrow key up and down zooms the timeline in and out (or vice versa). Look in the help file, there's a page of keyboard shortcuts, you will need to learn them for navigation.
Originally Posted by g_shocker182
the slider at the bottom of the timeline, where you would grab it and slide it back and forth to see different parts of your timeline?
grab an edge on it and expand it to zoom out of your timeline, or compress it to zoom in to your timeline.
hope this makes sense, if it doesn't let me know and I'll grab a screenshot of what I'm talking about...- housepig
Housepig Records
out now:
Also, File -> Properties -> Ruler
to change the ruler from time to frames (25/29.97) plus more. -
Zoom in/out horizontally in small increments (if timeline has focus)
Up/Down Arrow
Zoom in/out horizontally in large increments or zoom to selection (if one exists)
Ctrl+Up/Down Arrow
Zoom in time until each video thumbnail represents one frame
Alt + Up Arrow
though i do it the way house pig describes most of the time--"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Canon Powershot video to avi, and then into Vegas 9--no video
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 25th Jan 2012, 14:50 -
How can insert a video in timeline between other video files with Vegas Pro
By siopilos in forum EditingReplies: 2Last Post: 15th Jun 2011, 16:53 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 11:35 -
Compress video in Vegas 4 for Weepies video
By Knightmessenger in forum Video ConversionReplies: 3Last Post: 7th Jul 2008, 00:04 -
Need Vegas Video 4.0 help
By emcee143 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2007, 04:20
