Hi,
I'm planning to buy a hard drive with a external case (USB2/FW). Now I realise that hard disks are pretty fragile things - I've lost one recently when my pc was on and it fell on its side, killing the hard disk. I was just wondering, what are the dangers for having an external hard disk? I remember years back when people would park the "head" of the hard disk. Is this still available? Could people with an external hdd give me some of their experiences - preferably similar to what I want to buy as I know that there are some complete external units available (eg. Maxtor).
Appreciating any advice!
Kien
Harddrive are not are fragile as you might think.
From the Maxtor site , The DiamondMax® Plus 9 spec sheet.
I use a USB external for storing copies of my files : email, word docs, excel etc.Temperature
Operating (°C) 5 to 55
Non-operating (°C) -40 to 71
Shock
Operating Mechanical Shock 2ms (G) 60
Non-operating Mechanical Shock 2ms (G) 300
The enclosure has taken a fall (about 3 feet onto carpet) and still keeps on tickin'. (note : tickin' as in "timex watches - takes a lickin keeps on tickin')
Realistically think it through : Laptops use harddrives , are constantly on the move, bump ...bump.... know of any issues with them??.
Also .......
Any drive will do ,all you need is the enclosure. You can buy them separately then add the drive.....I know that there are some complete external units available ...
EG: http://www.orangemicro.com/fw800usb20hd.html
http://www.ramelectronics.net/html/usb_hard-drive.html
Firewire recommended . Oh ! and before the question is asked. NO No NO firewire it is not faster than an internal IDE drive.
800Mbps firewire is "megaBITS" or 800/8 = 100Mb/sec MAXIMUM . -
I have used a small mobile 2.5 inch 10 Gig hard drive for 2 years without any problems. It is surrounded with a silicon rubber cover and has USB2 and Firewire connections. Works great. Never dropped it on the floor, but I don't drop my cameras, CD players or the like. It has knocked around in my softside luggage quite a bit, though.
Edit: If you want something almost indestructable, you might look into a flash drive. Plugs into a USB port. 512Meg about $130US. 1Gig a bit more, but you can't hurt them. -
I don't have external drives, but I do have a removable tray drive (which would be even more stressful) and have not had problems.
As long as you don't put unnessisary strain on it, like throwing it haphazardly in your backpack, dropping it, doorstop, etc... you should be ok."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
