  1. I posted this here cause i dont know where else to post it since i am a big newbie to ripping etc.... and i found the tutorial on Divx(AVI) to (S)Vcd using DVD2SVCD and i got through everything using DVD2SVCD and encoding it and i dont know where to go from there. I got all thest files when i encoded
    -AviSynth_Script_file
    -AviSynth_Script_file.vaf
    -AviSynth_Script_file_avs-vfapi.mpv
    -dvd2svcd project file.d2s
    -Encoded_audio_1
    -ResampleAudio
    -AviSynth_Script_file_avs-vfapi.vaf
    -dvd2svcd_log
    -Intra.mtr
    -AviSynth_Script_file.mpv
    -DVD2SVCD
    -Encoded_audio_1
    -Non-Intra.mtr
    I am so lost and have no idea where to go from here. I read the tutorial and i still dont understand. ANy help would be greatly appericated. Thx
  2. Did DVD2ONE start to encode. DVD2ONE does not come with a encoder you need to install CCE 2.50 you can get it at www.doom9.org but you need Adobe premiere. You can also use TMPG and Canopus encoder. Whe you start to encode and you get your SVCD or DVD or Divx file ther are lft over file's you can delete. Just extra file left over that are not needed.
  3. i got everything made right and i have an image file but i dont know how to burn that on to a CD i use nero
  4. Who mentioned DVD2ONE?
    DVD2SVCD produces image files for SVCD's.
    You can use Nero to burn the images - open Nero, close any wizards etc.., then go to File->Burn Image, and navigate to the directory you've used for DVD2SVCD.
    From memory, I think DVD2SVCD produces .cue files which Nero recognises.
    cheers,
    mcdruid.
  5. if the other suggestions didn't work you can try the guide at www.MakeMeKing.com/howtodvd.html I know that definatley works for me. I've tried some of the other ways people have talked about and those work too however I believe this is a more reliable way
    Funny site at www.MakeMeKing.com haha
  6. theDruid
    is correct. DVD2SVCD produces bin/cue file sets for each CDR to burn. point nero or any other image-burning prog to the folder that has these sets and burn one after the other. good luck.
