Previously, I've been able to use FFmpegX with no problems. I've upgraded to Panther and 0.0.9a, and now the program doesn't seem to accept any VIDEO_TS folder on my harddrive. I've used DVDBackup as usual, but I now get:
"To comply with copyright laws, DVD device input is not allowed. Please select a file or a non-encrypted VIDEO_TS folder from your hard disk."
If I change the name of the VIDEO_TS folder to something else, it works, but then I don't get any audio... I read in this forum that it indeed needs to be named VIDEO_TS in order to get the audio. So... any suggestions? Thanks.
GrigsbyGuest
GrigsbyGuest
Thank you, that worked fine. But now I'm still having intermittant trouble having any audio... I was able to encode one divx, but now whenever I try, I get no audio... I haven't changed any settings except the Title #. Any ideas? Thanks. -Grigs
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
DVD device input not available WARNING!!!!
By crosseyedalien in forum ffmpegX general discussionReplies: 3Last Post: 5th Dec 2007, 16:38
