Hi. I've created a SVCD. I can play it at my computer, but at SVCD player, it's running but the display and audio don't come out. I created the cd using Ulead VideoStudio and burned it with Nero.
Can someone help me ? Thanks
I can play it at computer, but can't play it with my (S)VCD player. It's running, I can see the time running, but no display and audio come out.
What's your DVD player? Have you played SVCD's in it before? Have you tried your disk in another DVD player?
"Art is making something out of nothing and selling it." - Frank Zappa -
It's my first time to create SVCD since I was unsastisfy of VCD. I've tried to played it at another player, it's running but nothing come out.
My player is not DVD, but it said support for SVCD Version 3.1
Is that mean something ? -
Here's what I'd do....Make sure that your player can play an SVCD by getting a good disk and playing it, that will eliminate your machine. If the disk you made doesn't work in a machine that definitely supports SVCD then there's definitely a problem in how your disk was created.
Post your method step by step in creating your disk and then someone can offer some suggestions such as....try a different brand of disk, or try a CD-RW instead of CD-R."Art is making something out of nothing and selling it." - Frank Zappa -
I can play my cd at DVD player. I guess it's about my player do not really support SVCD. Thanks anyway.
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 20:04 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40 -
how to play seamless loop svcd's
By markwest in forum Authoring (VCD/SVCD)Replies: 8Last Post: 11th Aug 2007, 15:06
