I am using VideoStudio 7 to capture and then convert from Huffyuv to MPG2 (VBR-8000 720*480)
I have no problem and quality is good.
It takes about 2 hours to encode a 50 minutes file. I have a AthlonXP 2000+, 1Gig memory, and use 2 HD 7200RPM.
Is this normal speed?
Thanks![]()
Guest
that sounds okay.. some encoders are faster than others.
TMPG takes about 4-5x the material length (ie 4 hours for a 1 hour movie), with excellent quality.
MainConcept 1.3 only took 1.8x, but I didn't like the quality of the output file. so until I find a better encoder, I'll take quality over speed.
but 2x sounds decent, if you like the quality you're getting.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
CCE is real-time...
CBR is 1X and N-pass VBR is (N+1)X with same excellent quality as TMPGEnc. (In CCE N-passes is actually [N+1] passes because the first pass creates the VAF file, and then it does N encoding passes).
TMPGEnc is more flexible, CCE is faster, both are excellent. TMPGEnc is the winner for value/$$$.
I also tried MainConcept but was not impressed with the results. Too grainy for my taste.
vcddude -
even on my PII/350?Originally Posted by vcddude
that's one hell of a program....- housepig
Housepig Records
out now:
Oops, good point housepig!
I should have been more specific. CCE is real-time on MY system which has:
- 2.4 GHz Intel P4
- 512 MB RAM
- 200 GB HDD
So, no I doubt it would be real-time on a P2/350.
Also, MainConcept on my system was essentially real-time but as I said, the quality was not great.
vcddude -
I'd still suggest using huffyuv. It captures fairly easy with minimal dropped frames. On my 2.4GHz P4, I can get 720x480 and suffer maybe 1 dropped frame per 15 minutes. The only drawback is Huffyuv is a real space hog, easily eating about a Gig per minute.Originally Posted by disturbed1
Mjpeg isn't quite as good quality wise and could be considered if the hard drive space is tight or if you're having trouble with Huffyuv.
IIRC when I used TMPGEnc to convert to mpg2 (for DVD) it usually take me about 2-3 minutes for every 1 minute of captured video.
Speed up Virtualdub
By graphics in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2011, 20:13 -
Streaming, what speed do i need??
By brookey12 in forum Video Streaming DownloadingReplies: 5Last Post: 1st May 2011, 18:23 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 14:24 -
Internet speed
By Jomapil in forum ComputerReplies: 5Last Post: 8th Jan 2010, 10:00 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41
