  1. I'm trying to encode througth TMPGE a Divx but it tell me that the lenght of the movie is 400% longer than the real time.
    When I play the movie in a reader, the time is OK.
    Any idea to correct this?
  2. Have you tried encoding a sample, to see if it works? Or does this problem cause TMPGEnc to screw stuff up such as bitrate?
    I would think that if it plays OK in a player, TMPGEnc is just being a bit funny. Try encoding the first minute and see how it goes. If it doesn't work, could you describe what happened?
    Thanks,
    CobraDMX
  3. You need to convert the audio in the avi file into a seperate uncompressed wav file. Use goldwave or virtualdub to do this. Search the forum or user guides for more details.
