I have a video on my computer that has a real problem converting to any type. i prefer to convert to MPEG so i can make a VCD. The error is in kernel something. I need to solve this problem. Thanks. If it helps i had to use a new codec for Xvid. I tried TMPGEnc and U-LED video studio.
Have you had a look here ?https://www.videohelp.com/tmpgenc.htm#problems
particularly the 'increasing priority' solution. -
the problem is that the converting programs i use cant read the file of something. it keeps causing errors
Did you load it into Virtual Dub and select Video-->Scan video stream for errors?
Hello.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
