I was wondering if anyone has an idea about this problem. I recorded a movie off the TV on my Panasonic DMR-E50 in SP (2Hr) mode which plays fine on the DVD recorder and also when I play it on my PC via Power DVD,but when I transfer the file to the PC and play it again with Power DVD certain parts of the movie go split screen i.e sometime 2 quarters at the top and a static half screen at the bottom and sometime 1 half movie (left) blank on the right.I have also converted this to DVD via TPMGENC DVD Author and the DVD is the same.Any ideas anyone-Thanks...
Results 1 to 1 of 1
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 16:30 -
Need To Split A DVD-RW .VRO File
By 360Spider in forum DVD RippingReplies: 2Last Post: 21st Jun 2010, 11:55 -
having issue with playing or converting VRO file
By andy99 in forum Video ConversionReplies: 6Last Post: 30th Dec 2009, 06:27 -
ever heard of a vro file?
By uglijimus in forum Video ConversionReplies: 11Last Post: 27th Apr 2009, 23:30 -
how do you convert a vob file into a vro file?
By johnsteed in forum Video ConversionReplies: 29Last Post: 13th Sep 2007, 07:12
