"Pinnacle Studio cannot inicialize the video capture device" - that's the message I receive when trying to capture from my analogic camcorder.
I can chose the DC10 card from capture settings, but I cant make it works.
It worked great when I was using Studio7. I'd be glad if someone knows what should I do.
Thanks in advance.
My PC:
OS: XP
AMD 1.0
Asus A7V
HD 80 GB
RAM: 256
I don't know what the problem is. I got that message a few times and restarting the computer or reinstalling the drivers would usually solve it.
If you can't get it to work, reinstall Studio 7.
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Miro DC10 + Fedora core 8
By bmw524 in forum LinuxReplies: 5Last Post: 7th Jul 2008, 07:28 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 17:12
