I am using Easy VCD DVD to copy an avi file. The picture isd great,
but the sound is all distorted.The original sound sound is fine.
I have tried using TMPGENG Plus 2.5, but it will not accept the audio
file, I get an error message. Tried to split the audio using Virtual Dub
but when you open the file information it says Compression: Unknown
(Tag 2000). When I try to save the file it comes up with another error
message: File compreeor could not be found, and will not let me save the file.
ANY HELP PLEASE.![]()
You have Ac3 audio. Search the forum/guides for more help as there is loads of info on how to handle this but its not just a one liner.
Thanks for the info.
I have had a long look around without much luck. I have ac3 filter loaded,
and have now downloaded ac3 codecs as well.
Could you point me in the right direction.
Thanks for your help.
name/cause of this video distortion?
By spiritgumm in forum Newbie / General discussionsReplies: 8Last Post: 29th Mar 2012, 11:24 -
Easycap USB adaptor and Windows Vista Ultimate - Sound distortion problem
By Eric544 in forum Capturing and VCRReplies: 4Last Post: 10th Jun 2011, 15:52 -
Sound distortion when play CD on Magnavox ZV457MG9A
By AliceWonder in forum AudioReplies: 1Last Post: 12th May 2011, 11:16 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 16:13 -
Distortion when played on TV
By tomhopkins in forum Authoring (DVD)Replies: 4Last Post: 18th Jul 2009, 15:36
