I need to capture video from VHS. What's a good reslolution to use, and what format should I capture into? (MPEG 1/2, DivX, or Uncompressed AVI)
I plan to put the captured files onto VCD/SVCD and keep them to watch on my PC.
if you're going to put them on SVCD, use 480x480 (480x576 for PAL).
If you're only going to watch them on your PC, then I'd capture at 640x480 and convert to DivX.
What is the best format to capture and archive HD DV content.
By nashmarkt in forum Capturing and VCRReplies: 8Last Post: 10th Dec 2009, 14:41 -
Best format to capture in?
By Canopus Smoker in forum Newbie / General discussionsReplies: 10Last Post: 27th Nov 2008, 15:14 -
what is the best format when capture from tv show?
By sumeshkri in forum Capturing and VCRReplies: 10Last Post: 23rd Feb 2008, 19:35 -
WMV Format Capture
By zerohash in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 09:48 -
best capture format and software
By boots in forum Capturing and VCRReplies: 11Last Post: 27th Jun 2007, 20:54
