Actually, this a little refinement of another item I have recently posted. Since, reinstalling a new operating system/programs on my computer, the caputer device of my DVC 150 does not operate correctly for SVCDs. It only captures 48 kHz audio resolution, never 44.1.
I suspect it may be due to my only having the old driver supplied by DAZZLE. I have version 3.20. However, I think here was a version 3.40 posted on the DAZZLE website, which is probably what I had previously. The old DAZZLE website is gone.
Does anybody have that upgrade driver?
Hi,
IN A HURRY . PINNACLE BOUGHT DAZZLE; this may help :
latest driver download page:
http://www.pinnaclesys.com/SupportFiles/Downloads/
Driversanddownloadspages/update_dvc150.htm
latest moviestar download page:
Driversanddownloadspages/update_hw.html
all dazzle products driver&software download page:
http://www.pinnaclesys.com/docsupport1.asp?
division_id=1&langue_id=2&product_id=1470
&product_name=&page_id=837
and
http://www.b2tek.com/dazzle/
and
http://beckerpm.dyndns.org/
Greetings
tom[/url]greetings
tom -
Thanks for the links. Just to be sure are these for original DAZZLE software or for the Pinnacle?
Hi,
as far as i know the links link to the original soft included with the dvc150, be careful, the lines have been split.
eg: dvc150v340.exe are the "pure" drivers.
Pinnacle has other links for dvc capable version of their studiosoft.greetings
tom -
Thanks much again. I downloaded the upgrade and installed it. Unfortunately, my "problem" continues. I cannot capture 44 kHz audio no matter where I set it. Actually, I get the impression that it is outputing something strange. In TMGenc the audio is recognized as 48 kHz, but the audio finishes before thevideo and is mickey mouse.
I reset the DVX to "48" kHz and then ran the captured file thru GraphEdit and included a resolution filter that outputs 44. That produced a good SVCD.
So, what I am saying is that if I set the DVX to 44, then the result is recognized as some sort of screwed-up 48. If I set hte DVX to 48, I really get 48, but can convert it to 44.
By the way, just for grins, I set the DVX to 32. The result was the same as setting it to 44. -
Hi,
as far as i know, the dazzle captures audio in LPCM format, the 48/44 switch is "for future use".
By the way : "multiplexing" 48 to 44 is what Moviestar does when it "renders" a (s)vcd.
I also prefer graphedit or other tools. Graphedit (the filewriter) quits working at 4GB.greetings
tom -
Again, thanks for the info. As it turns out, I see no difference with the new driver. I now leave that sampling rate button alone. If you choose something else, the results go into the toilet.
I also now realize that it doesn't matter if I use a 48 to 41 kHz sampling rate converter in GraphEdit or not. It appears that VCDEasy corrects the audio. I made the same SVCD twice. The first time, I first converted the audio to 41. In VCDEasy, I saw no error messages about the audio and got a perfect disc. I then remade it, this time not converting the audio to 41. VCDEasy, displayed a brief error message that the audio was at 48 and then went about doing what it does. The results were also perfect.
Mike -
hello everybody, i have the solution.
after to try and try i found it.
the problem is that the drivers dvc 150 in to the original pack (with the box) they arent correct and the pinnacle studio quickstart dont work with dvc 150.
the solution is download this driver
http://www.pinnaclesys.com/WebVideo/Stu ... CLEUSB.exe
in actually, im using this drivers with pinnacle studio 9
work in pinnacle studio quickstar, 8,9 !! perfect capture!! drops frames 0
good luck!!
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum Capturing and VCRReplies: 17Last Post: 23rd Dec 2010, 23:46 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Best utility to backup drivers?
By alegator in forum ComputerReplies: 2Last Post: 20th Jan 2009, 15:50 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34
