  1. http://www.mediachance.com/dvdlab/history.html
    Version 1.3 BETA 6 (download dvdlabup13beta6.exe (4.2 MB) - you need to have installed at least full 1.1 version)
    Release candidate
    - Finally fix for the PAL hi-lite bug that affected few PAL players such as Samsung, Bush, Cyberhome
    - Fix for some very rare cases when the background of highliting area can become visible (blue).
    - Added displaying of Average Bitrate in Assets and in connection
    -Some GUI fixes, added reset toolbars.
    -Save, Cancel fix (file was saved anyway)
    -Fix Force Selection on motion (couldn't select any other button than selected)
    -Fix Force Activate on still menus with audio
    -Added Bitrate Viewer for detailed examination of actual bitrate over the whole movie.
    -Added Rewrite GOP timecode tool
    -Warning if Average Bitrate of input files is too high
    -The Import chapters saves the chapterpoints also as frame number so at compile you can choose between fast (timecode) or precize (Frame-Index) chapters.
    - Allows adding Frame-Index chapters even if the GOP timecode is missing.
    - Since Pinnacle uses *.MP2 as Video, but some people have *.mp2 as audio, to avoid confussion DVD-lab now understand *.mp2 as video but offers renming it to *.mpa if user imports an audio with this extension.
  2. thanks for the heads up
