I have tried 3 different DVD+R'S compusa,Arita made by Ricoh and TDK.none will play in my Apex AD-1201 DVD player.they all will play on my computer in the Optorite drive.my uncle tried the compusa DVD+R in his DVD player.it does the same thing 'NO DISK".another problem with DVD-RW'S they freeze up.I have only optodisk DVD+RW'S so I guess it could be the media.DVD-R play's great in my Apex.a friend of mine had a DVD+RW generic no name and it played on my Apex fine.he has a HP 300i.
My Apex 1201 plays:
Ritek G04 4x -R
TDK 2x -R
Ritek 2x -RW
Princo 1x -R (don't ask, it's a gift)
Memorex 2.4x +R
and a few others I can't recall.
Sounds like yours is deffective, dirty, or a revision in the model? When did you buy it, what's the serial number manufacturing date (not whole number).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I just bought it last week. manufactured july 2003.I flashed it to firmware v2.16.I have to use multisession on DVD-R'S or they won't play. s/n ALA21102237039013.what kinda software are you using?
Original Firmware here. Flashing for multi-session DVD-R's sounds ominus. Are you sure? I mean I don't close my RW's an it reads them just fine.
Originally Posted by idlertire
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
