I use macromedia fireworks and recently, I havent been able to save files other than png. It doesnt give me an option to select the filetype and even if i type in xyz.jpg, it automatically saves it as png. I used to be able to save as any extention but its just not working for some reason. I'd go to paint but that screws up the picture. Does anyone know how to fix this?
G fawkes is very good on fireworks. 8)
File > Export (or CTRL+Shift+R)
Type in the filename you desire and by default it should save to JPEG
PNG to PDF via Fireworks; best settings? image attached
By sdsumike619 in forum ComputerReplies: 4Last Post: 27th Jan 2010, 04:46 -
Waterfall / rain fireworks in after effects or vegas
By blacksheepdownunder in forum Newbie / General discussionsReplies: 4Last Post: 19th Jan 2010, 16:17 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Free Fireworks Stock Footage
By joelholland in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:14
