Is playback performance the only reason someone would downsample a 720*480(720*304 for widescreen) source (like a dvd) to 640*480 or less?
Yes.
Look, if you take a 5 GB MPEG2 DVD, and convert it to DivX, with the AC5.1 audio track, and you leave it 720x480; it will be 2 GB when you done with no artifacts.
Most people don't want a 3 CDR DivX movie. So, they turn the compression up and the resolution down. This drives the bitrates down to the 2 CDR level. 1 CDR DivX are strictly VCD resolution only. 2 CDR movies are usually 'good enough' for most people, especially if it's 2-pass VBR.
Also, most people confuse Resolution with Aspect Ratio. A 640x480 DivX is truly 4:3. Since a computers pixels are square and a TV's are rectangles, aspect ratio and resoltuion can be different. 720x480 is 4:3 on a TV, but not on a computer.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
gazorgan,
So let me ask you this, if i were to take a 2 hour movie, and convert it to 720*306 w/ 384 kps ac3, do you think 1.46GB (1/2 of a dvdr) would be enough to maintain (in general) high quality?
Also, since you brought it up, a question of aspect, i'm making some divx movies with intention of watching them primarily on a tv. To this end i will use a tv out video card or the XCard from sigma. I think my tv out card can support NTSC resolution(720*480), but i'm not sure how the XCard handles resolution ratios. I'm just trying to decide on the optimal resolution for divx to most faithfully reproduce the original NTSC source, i don't care about the bitrate as long as i can get 2-3 movies on 1 dvdr.
what do you advise?
Pioneer DVR-640 HS - can it record in PAL?
By Spiny Norman in forum DVD & Blu-ray RecordersReplies: 6Last Post: 24th Aug 2010, 17:16 -
how to record with 640*352 format
By Haboob1st in forum DVB / IPTVReplies: 5Last Post: 3rd Jun 2010, 19:39 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25 -
Would 640 X 272 to 720 X 400 be correct?
By hydrophonicaudio in forum MacReplies: 19Last Post: 24th Jul 2007, 11:33
