Ok, as a newb to all this, I gotta question. I've read guide after giude after guide and still have the same questions. I recently bought a Panny e80 so I'm learning it. BUT, I've decided I want to go a step further by getting a dvd-burner for my pc, create a dvd-ram disk on the Panny from a recording on the e80 hard drive and edit on my PC. I bought an LG 4040b burner. I would like to preserve dolby 5.1 and believe I read if using a dvd-ram disk, and editing on my pc that this is possible. What's the best software to use to divide my production into chapters (with thumbnails preferably), add a decent or nice menu and chapter section and burn to a highly compatible dvd-r? If anybody can also while suggesting software, suggest a plan of attack on how to do this, I would really appreciate that as well.
Thanks so much!
You are the only person on earth who best answer that question for you, as you know what you are best at. Read the beginner's guides and the DVD Authoring section. Look at the guides and see which ones look easiest for you. What is easiest for me may a bear for you and vice versa.
"Trust your feelings, Luke"Hello.
What Is The Easiest Video Editing Software For Beginners That's Free?
By Joshua P in forum Newbie / General discussionsReplies: 19Last Post: 16th Apr 2013, 08:24 -
Cheapest/easiest software to create an electronic personnel action form?
By wetcamelfood in forum ComputerReplies: 2Last Post: 15th Jan 2012, 07:58 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 12:31 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 12:43 -
what is the easiest software to cut an audio file?
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 13:45
