I have downloaded this from the net - bought a serial number and it is not working.
It fails at the part when it is supposed to commence "burning" process. I get a statement that says Burn Process Fail.
Can someone tell me if this is related to the software or some buttons which are checked or not checked with my operating system? I am using Win. 98.
I had no problems using Nero in the past but my computer crashed and I had to reinstall everything.
Thanks.
Also, are there any other great MP3 softwares out there which are FREE and have a volume normalizer?
you just bought a license for ver 5.5? it's been out for years, plus if you already have a ver on your (old) system it should be a free upgrade...unless you are talking about ver 6.
anyway if you can go back to ver 5.5.10xx.
RE your burning issue too many variables are at play here since very little info was provided other than error message. try reinstall nero first. good luck
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Question about BD-ROM
By II AnDo II in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th Dec 2008, 19:39 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 11:29 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54
