  1. Hi all,
    My friend used a screen cleaner to do his laptop screen, and this left a bit of a smear on the screen. Is there anything that I can use to clean the cleaner off it?
    Thanks!
    CobraDMX
    USA
    Probably get flamed for this, but I use small isopropyl achohol swabs pads you can get in any drugstore. Used for cleaning skin before injections. From what I can find out, most manufactures of laptops seem to recommend isopropyl alcohol diluted 50% with water. The swabs are a little higher concentration, but they work well and are lint free. You can buy a box of a hundred for a few dollars.
  3. I recommend Endust for Electronics coupled with a 3M or comparable brand microfiber, lint-free cloth.
  4. Banned
    Nov 2002
    Pgh Area
    Definitely ssome kind of plastic safe cleaner.
    My own is called "Static Free SD-7 Plast-N-Glas".
    Safe on most plastic LCD screens. Note I said on most.
    No guarantees here.
    Cheers,
    George
  5. I got a bottle of propan-2-ol (isopropanol alcohol) and it did a fantastic job of my friend's screen.
    redwudz, thanks for the suggestion!
    Now, what to do with the remaining 490ml... FIRE!!
    CobraDMX
