  1. Does anyone know if it is possible to rip a VCD, and is so how?
    I have a few original PAL VCD's which will of course play on my NTSC DVD player but the picture is squashed (I have a multi-standard TV)! I want to convert them to NTSC.
  2. To rip a VCD just pull the .dat file out and rename it to .mpg. It should be as simple as that.
    -SlaveUnit
    If you can't hate yourself, who can you hate?
  3. Thanks, yes that has done the trick.
  4. Renaming the file does not yield a compliant MPEG. You should always run the MPEG file through VCDGEAR.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. vitualis, ya...but if he uses nero to make a compliant VCD...i don't think he has to go throu VCDgear
  6. If he used Nero, he also wouldn't have had to rename it to .mpg either...
    Regards.
    Michael Tam
  7. vitualis, heh...got me there dude
