HI
Can anyone please help me, i'm new to all this so please bare with me. I am using unlead dvd movie factory 2 and when I try to encode an avi file to dvd using the automatic conversion after I have made my menus, it always gets to around 60 to 80% and then I get error messages. I can't remember exactly what they say but I've had at least 2 different ones. It has also done this when using tmpegne.
Please help
thanx
sounds like a bad avi file, why not download winmpg video converter, convert the avi to mpeg (if you can) then burn using you favourite burning app? but sounds like the file got some errors in it or something. i think you can down load a tool to fix avi files, its at www.fixvideo.com it should sort the problem avi out for you.
It now works and the dvd copies fine but when I play it in my dvd player about 20 mins from the end the audio stops and the video continues.
HELP ME!
MeGUI x264 encoding problem. Video stutters/flickers.
By EasyDrama in forum Video ConversionReplies: 17Last Post: 21st Mar 2014, 00:36 -
Problem while encoding AVCHD video with Sony Vegas
By RiDDleR2 in forum EditingReplies: 6Last Post: 29th Jul 2011, 11:41 -
Encoding a Video-Divx got Size Problem...
By PzSniper in forum Video ConversionReplies: 3Last Post: 17th Sep 2009, 18:59 -
Problem with Interlaced video & Encoding
By miluv2u7 in forum MacReplies: 0Last Post: 19th Jun 2007, 11:55 -
problem encoding error decompressing video frame 0 :
By goingape in forum Newbie / General discussionsReplies: 7Last Post: 27th May 2007, 14:14
