I recently bought this model and everything works great except it refuses to write at 4x. I have tried a few dif progies and dif media yadayada.....and no luck in every compilation i do it says it burning at 4x and states it'll be done in 15 mins but eventually it juts takes roughly 28 mins.....i would rather not upgrade my firmware as i c many people having even more problems when doing so. Is their any possible fix for this without firmware upgrading???
What media are you using ? You might have bought different brands only for it to have been made by the same manufacturer...
I suggest getting hold of something like DVDinfo Pro and checking the media ID's. -
I had this same exact problem until I upgraded my Windows operation system from ME to XP.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
A good, "easy" program that can edit a DVR disc?
By Arglameth in forum EditingReplies: 1Last Post: 23rd Feb 2009, 10:58 -
Will digital broadcasts have "IDs" to aid in DVR recording?
By ebenton in forum DVB / IPTVReplies: 10Last Post: 26th Apr 2008, 05:55 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
