HI,
I'm almost reaching the perfect SVCD point with TSCV, but my only problem is that I can't get the MEdiaplayer window to display anything but black in TSCV.
I use Win2000 pro, service pack 1, I installed the MPEG2 ax filters as stated in TSCV site, but still, I can't get any picture. I also tried to start a capture software to activate overlay as some users adviced, but no luck.
If someone here knows how to solve this, this would really help me create accurate chapters on my SVCDs.
Thanx.
Waldok.
I have given up using mediaplayer to display the movie. When I switched to using vfapi (use version 1.03), it worked. Enable vfapi under Settings. Installed vfapi 1.03 and start the reader. Load the mpg file and convert to avi.
To Waldok: I have your same configuration! Yesterday I was able to use TSCV
Try to get the latest version on both TSCV (v.074 beta rel.19 and VCDI Imager 0.7.10, but also VFAPI reader codec 1.03 B.
You find it in TTTool site, on a FTP server (Just look in their forum). DO REMEMBER to set TSCV well (Point the right Path to VCDI;To TMPGENC and click on "enable VFAPI ecc)than just load your MPEG file in VFAPI and convert. Yopu get an AVI file (Small) and you're in. easy like a glass of water
It takes two weeks.....
Francesco Landi
Medicina, Italia -
Grazie Mille, Francesco
And thanx to ipf too !
I'll try this VFAPI thing tonight (althoug hI'm not sure I understood everything about it !)
I'll let you know how it goes.
Waldok
MediaPlayer 9 not playing MovieMaker wmv
By Punchcard in forum Video ConversionReplies: 3Last Post: 6th Dec 2010, 11:53 -
Convert DVD to ? for my mediaplayer
By daniel_c in forum Newbie / General discussionsReplies: 7Last Post: 29th Mar 2009, 14:19 -
RealMedia/MediaPlayer Classic
By JackPollack in forum Software PlayingReplies: 0Last Post: 18th Jan 2009, 19:36 -
MediaPlayer Classic - wrong aspect?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 8th Sep 2008, 13:03 -
Is there any FREE mediaplayer for use on symbian OS?
By bacardi/avt in forum Portable VideoReplies: 6Last Post: 30th Aug 2007, 11:41
