  1. Anonymous
    Guest
    Hi folks,
    I try to run this fine app my G5 Os X 10.2.8, I prepared a video, locate the files with ffmpegx and run it.
    I got a finish in one sec (hmmm the G5 is fast but not so fast) when opening the terminal I got this message:
    dyld: /usr/bin/mencoder can't open library: /usr/local/lib/libvorbis.0.dylib (No such file or directory, errno = 2)
    sh: line 1: 575 Trace/BPT trap /usr/bin/mencoder -dvd 1 -dvd-device /Volumes/X\ Zone/TEST_MOVIE_/VIDEO_TS -dvdangle 1 -oac mp3lame -lameopts cbr:br=128:vol=0 -aid 128 -ovc lavc -sws 0 -lavcopts vcodec=mpeg4:vbitrate=2328:keyint=240:vqmin=2:vqma x=15 -ofps 25 -vop scale=720:544 -o /Volumes/X\ Zone/LAKE_PLACID_/movie.avi
    So a helping hand is needed
    Regards
    Thx
  2. You forgot to run the installer. Try again by following the instructions.
  3. Anonymous
    Guest
    thx Major for the response
    But i did it like the install instructions says it, so it did for to be sure again and it still not work.
    But I read now that you can do it manual? Can you direct me to the right dir/folder? I don’t find it? maybe this will work?
    Or could it be an other problem?
    Regards to you all!
    Thx.
    R@ven.
  4. Anonymous
    Guest
    Hey Major,
    I found the problem and you where right, I forgot something to install!
    I did the ffmpegX engines installer with the extra 3 files and I copy the ffmpegX file to the App folder so I forgot the ffmpegX_0.0.9_installer
    hehehehehehe stupid me
    Thx
    Regards
    R@ven
